[OpenLayers-Dev] SLD parsing and rendering
Cameron Shorter
cameron.shorter at gmail.com
Thu Oct 18 04:41:40 EDT 2007
Yes, thanks for all the hard work on this thread.
Tim Schaub wrote:
> Hey-
> This is great work - and a huge contribution to OpenLayers! I look
> forward to taking some time with it. Just a quick thanks for putting it
> all together.
> Tim
> Andreas Hocevar wrote:
>> Hi,
>> the SLD parsing and rendering component (#533, [1]) I was working on
>> with Pierre Giraud of Camptocamp at the FOSS4G code sprint is now
>> ready for review. Since the code sprint, there have been major
>> improvements:
>> * OGC filter rules are no longer translated to JavaScript eval
>> snippets. There is a new object hierarchy under OpenLayers.Rule with
>> classes to store and evaluate rules. The big advantage of that is not
>> only performance, but also that it is much easier to use as a starting
>> point for a SLD editor that has to store rules and write them back to
>> a SLD file.
>> * More of the OGC filter spec is supported, namely the PropertyIsLike filter.
>> * Parsing of sld:NamedLayer/sld:Name and sld:UserStyle/sld:IsDefault.
>> Based on that, vector layers can now take the whole result hash of
>> OpenLayers.Format.SLD.read() as style property and automatically use
>> the default style for the NamedLayer that has the same name as the
>> vector layer and is marked as IsDefault.
>> * Improved example with the Tasmania data set from Geoserver [2]. The
>> first version of this was contributed by Alex of Lisasoft, along with
>> thorough testing.
>> * TestAnotherWay tests for basic functionality of all new classes.
>> * Improved code readability and comments.
>> * Changes on the OpenLayers trunk codebase are limited to a few lines
>> in two files: Layer/Vector.js and Control/SelectFeature.js
>> Please have a look at it, I hope you share my opinion that this thing
>> is ready for moving it to trunk. If not, feel free to comment on it
>> and tell me what to improve.
>> Once this is finished, it will be used for styling vector layers in
>> Mapbuilder based on the SLD properties in View/OWS Context documents.
>> It should also be a solid ground to build a SLD editor upon.
>> Regards,
>> Andreas.
>> [1] http://trac.openlayers.org/ticket/533
>> [2] http://dev.openlayers.org/sandbox/ahocevar/sldRenderer/examples/gml-tasmania-sld.html
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
>> !DSPAM:4033,4716721d30071804284693!
> Dev mailing list
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev
