[OpenLayers-Dev] status of translation possibilities
Erik Uzureau
erik.uzureau at metacarta.com
Thu Oct 18 13:23:27 EDT 2007
or maybe to keep the namespaces straight and clean, more like this:
OpenLayers.Strings.languages['english'] = {
'foo': "Foo for president",
'bar': "Bar for gardner"
OpenLayers.String.setLanguage = function(lang) {
OpenLayers.Strings.language = lang;
OpenLayers.String.get = function(strKey) {
return OpenLayers.Strings.languages[OpenLayers.String._language][strKey];
and so:
OpenLayers.getString('foo');
or
OpenLayers.String.get('foo');
On 10/18/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> I like this idea a lot. we make a /lang directory and a separate file for
> each language. also the use of JSON I think is crafty.
> the file could look something like:
> OpenLayers.Strings['english'] = {
> OpenLayers.String._language = lang;
> return OpenLayers.String[OpenLayers.String._language][strKey];
> and so:
> or
> this is off the top of my head.
> On 10/18/07, Dan Little <danlittle at yahoo.com> wrote:
> > I wouldn't think this to be too hard.
> > In most internationalized applications I've seen, there is typically a
> > "lang" or "strings" file that contains all of the strings for a given
> > application. Then when the code needs a string it will call a global
> > variable containing that error/warning/info message. This way all of the
> > needed translation is isolated to a single file. Changing languages becomes
> > a matter of loading an alternate language file.
> > So there could be a collection of language files:
> > strings.en.js
> > strings.es.js
> > strings.fr.js
> > strnigs.de.js
> > And then provide some basic facilities for switching between them. In fact,
> > each of those files could be a JSON object that gets loaded to a global
> > object/variable.
> > I may be just spewing bad ideas... but so long as the creative juices were
> > flowing I'd thought I'd share.
> > -Duck
> > ----- Original Message ----
> > From: Jachym Cepicky <jachym.cepicky at gmail.com>
> > To: Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
> > Cc: "dev at openlayers" <dev at openlayers.org>
> > Sent: Thursday, October 18, 2007 8:58:42 AM
> > Subject: Re: [OpenLayers-Dev] status of translation possibilities
> > Bart van den Eijnden (OSGIS) píše v Čt 18. 10. 2007 v 15:44 +0200:
> > > Hi Chris,
> > > I think it is acceptable to have a global setting. I can't imagine a
> > > common use case (for myself) where one map would be in English and
> > > another one in Dutch on the same page. It is important though that it is
> > > possible to switch languages.
> > +1
> > jachym
> > > Best regards,
> > > Bart
> > > Christopher Schmidt schreef:
> > > > On Thu, Oct 18, 2007 at 03:23:50PM +0200, Jachym Cepicky wrote:
> > > >> Hi,
> > > >> I would like to ask about the status of OpenLayers language support.
> > > >> There are not many strings, which could be translated, however, some
> > are
> > > >> there and IMHO we should (de)find a way, how to make this possible. Was
> > > >> there some discussion to this topic?
> > > >> IMHO, new map attribute "lang" should be defined, as well as new method
> > > >> OpenLayer.Util.getOLString("English text") (or similar).
> > > >> Any suggestions? Should I write something like this? Is there already
> > > >> some code out there?
> > > > No code yet, but I agree that now is the time.
> > http://trac.openlayers.org/wiki/RFC/Internationalization
> > > > Is my start at an RFC, which never went far enough.
> > > > My belief is that we should make this a global setting, rather than a
> > > > per-map configuration. This would mean you could not have multiple
> > > > languages on the same page at the same time, but would also mean you
> > > > don't need a reference to the map object in order to get a correct
> > > > translation string. I don't know if the trade off is worth it. What do
> > > > other people think?
> > > > Regards,
> > Jachym Cepicky
> > e-mail: jachym.cepicky at gmail.com
> > URL: http://les-ejk.cz
> > GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam? Yahoo! Mail has the best spam protection around
> > http://mail.yahoo.com
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
More information about the Dev
