[OpenLayers-Dev] proxyHost cgi issue
Domenico Febbo domenico.febbo at gmail.com
Tue Oct 23 04:28:29 EDT 2007
I need to use proxy.cgi script to forward "get" request on
XMLHttpRequest object to a external host, but I have same problem with
the path to add at "url=" field.
Moreover I've tried the online script
http://dev.openlayers.org/sandbox/docs/examples/proxy.cgi
but the http://openlayers.org redirect seems to have a issue because
the OpenLayers object isn't found (try with Firebug enabled) and all
the relative path are wrong.
Somebody have other proxy script for Apache webserver?
thanks,
Domenico
More information about the Dev mailing list
