[OpenLayers-Dev] Layers into Groups
Lorenzo Becchi lorenzo at ominiverdi.com
Tue Oct 23 18:21:10 EDT 2007
Jachym, I see that all legend layouts can vary a lot.
what about Tim's idea to use templates?
I'm pretty scared about it but probably is a good solution.
Tim, do you think templates could really apply to Layer switcher without
getting mad? if yes can you "enlighten our way"?
ciao
lorenzo
> A while ago I experimented a bit with a custom layer switcher outside
> the map window, it still seems to be working at
> http://www.yunnanexplorer.com/mars.html
> <http://www.yunnanexplorer.com/mars.html>
you've never tried it with Safari. Layers names disappears if you click
on them.
> There were several ideas in it:
> First of all ignore the tick-boxes -- they flicker a layer on and off.
> This is not very intuitive. I thought once having a special effects
> div hidden with every layer that could be turned on and off.
> Flickering a layer, moving a sliding window over a layer, inverting
> colours, image stretching could all go in there. Never followed through.
> The sliders allow to adjust transparency of a layer: red all the way
> to the left is off, green is 100% opaque. The rest somewhere in the
> middle: good way if you want to look at data in more than one map at a
> time.
> Furthermore it is possible to drag the layers up and down, changing
> the stacking/drawing order. I know that conflicts with the baselayer
> concept of OL.
> These effects were done with scriptaculous and do not really work that
> well under IE, but someone with more patience/time than me could
> probably make them work. It is now over a year old and I have not done
> any work on it, so some of the layers have ceased to function.
> I think building better/different layer switchers, particularly with
> grouping, is quite important...
> Ludwig
> On 23/10/2007, * Jachym Cepicky* <jachym.cepicky at gmail.com
> <mailto:jachym.cepicky at gmail.com>> wrote:
>     Hi,
>     could anybody of you, guys, have a look at new "custom LayerSwitcher"
>     example [1] ?
>     I hope, it works on all platforms
>     Comments are more  then welcomed
>     Jachym
>     P.S. You will have to probably zoom to Canada, go get all layers work
>     [1]
>     http://dev.openlayers.org/sandbox/jachym/openlayers/examples/layerswitcher.html
>     Jachym Cepicky píše v Po 15. 10. 2007 v 13:20 +0200:
>     > Hi developers,
>     > I have implemented ordering map layers into groups [1]. You have to
>     > specify new layer attribute group:"Group Name", e.g.:
>     >  var dm = new OpenLayers.Layer.WMS ( "DM Solutions Transit",
>     >                 "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
>     >                 {layers: "rail,road",
>     >                  transparent: "true", format: "image/png"
>     >                   group:"Transit"
>     > You can define group hierarchy using "/" mark:
>     > group: "Transit/Roads"
>     > Only changed file is LayerSwitcher.js
>     > For example see [2]
>     > Hope, you'll like it
>     > Jachym
>     > [1] http://trac.openlayers.org/ticket/1086
>     > [2]
>     http://dev.openlayers.org/sandbox/jachym/openlayers/examples/layer-groups.html
>     > _______________________________________________
>     > Dev mailing list
>     > Dev at openlayers.org <mailto:Dev at openlayers.org>
>     > http://openlayers.org/mailman/listinfo/dev
>     Jachym Cepicky
>     e-mail: jachym.cepicky at gmail.com <mailto:jachym.cepicky at gmail.com>
>     URL: http://les-ejk.cz
>     GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>     Dev mailing list
> Dev mailing list
More information about the Dev mailing list
