[OpenLayers-Dev] Layers into Groups
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Oct 24 03:59:17 EDT 2007
Ludwig M Brinckmann píše v Út 23. 10. 2007 v 21:06 +0100:
> Hi Jachym,
> for me on XP and Firefox 2.0.0.8 this appears quite unresponsive, even
> though after a bit of clicking something eventually happens. I am not
> sure about the graphical solution as I do not really know when a layer
> is switched on or off.
Some layers were active only, if you zoomed to region around Canada
(fixed). I completely agree with you, that the "design" of the page
"could" be more intuitive -- sorry, no graphical designer.
> A while ago I experimented a bit with a custom layer switcher outside
> the map window, it still seems to be working at
> http://www.yunnanexplorer.com/mars.html
> There were several ideas in it:
> First of all ignore the tick-boxes -- they flicker a layer on and off.
> This is not very intuitive. I thought once having a special effects
> div hidden with every layer that could be turned on and off.
> Flickering a layer, moving a sliding window over a layer, inverting
> colours, image stretching could all go in there. Never followed
> through.
nice demo
> The sliders allow to adjust transparency of a layer: red all the way
> to the left is off, green is 100% opaque. The rest somewhere in the
> middle: good way if you want to look at data in more than one map at a
> time.
this is somehow more intuitive, than my previous layer-buttons.html
example. Sliders are better for opacity settings, but I did not know,
how to get them in current LayerSwitcher dimensions.
> Furthermore it is possible to drag the layers up and down, changing
> the stacking/drawing order. I know that conflicts with the baselayer
> concept of OL.
Dragging is definitely more intuitive, than buttons (again
layer-buttons.html in my sandbox), when it is working. Together with
layer groups (layer-groups.html), the code would get pretty
complicated..
> These effects were done with scriptaculous and do not really work that
> well under IE, but someone with more patience/time than me could
> probably make them work. It is now over a year old and I have not done
> any work on it, so some of the layers have ceased to function.
> I think building better/different layer switchers, particularly with
> grouping, is quite important...
I'm working on it. If others like it, I hope, it would appear in
OpenLayers trunk - I'm not avare of any other impediment.
Jachym
> Ludwig
> On 23/10/2007, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> could anybody of you, guys, have a look at new "custom
> LayerSwitcher"
> example [1] ?
> I hope, it works on all platforms
> Comments are more then welcomed
> Jachym
> P.S. You will have to probably zoom to Canada, go get all
> layers work
> [1]
> http://dev.openlayers.org/sandbox/jachym/openlayers/examples/layerswitcher.html
> Jachym Cepicky píše v Po 15. 10. 2007 v 13:20 +0200:
> > Hi developers,
> > I have implemented ordering map layers into groups [1]. You
> have to
> > specify new layer attribute group:"Group Name", e.g.:
> > var dm = new OpenLayers.Layer.WMS ( "DM Solutions Transit",
> "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
> > {layers: "rail,road",
> > transparent: "true", format: "image/png"
> > group:"Transit"
> > You can define group hierarchy using "/" mark:
> > group: "Transit/Roads"
> > Only changed file is LayerSwitcher.js
> > For example see [2]
> > Hope, you'll like it
> > Jachym
> > [1] http://trac.openlayers.org/ticket/1086
> > [2]
> http://dev.openlayers.org/sandbox/jachym/openlayers/examples/layer-groups.html
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Jachym Cepicky
> e-mail: jachym.cepicky at gmail.com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> Dev mailing list
Jachym Cepicky
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071024/c76f73ae/attachment.bin
More information about the Dev
