[OpenLayers-Dev] deactivating other handlers
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Oct 25 04:57:37 EDT 2007
Hi devs,
I've written a FeatureInfo Handler, which only uses click. However, the
DragPan handler for instance is still active.
What is the best way to deactivate these other handlers?
Ofcourse I can also implement mousedown etc. and not let the event
propagate, but that seems a bit cumbersome.
Is there a way to make a Handler exclusive, or to remove all other handlers
from the map?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
More information about the Dev
