[OpenLayers-Dev] jpeg vs jpg
Paul Spencer
pspencer at dmsolutions.ca
Thu Oct 25 08:57:02 EDT 2007
No. TileCache saves the image with a .jpg extension but uses 'jpeg'
for the mime type of the returned content. The underlying library,
PIL, will do that automagically for you.
Cheers
Paul
On 25-Oct-07, at 8:53 AM, Jachym Cepicky wrote:
> Hi,
> no, if I understand it right, TileCache will always save the files
> with
> extension "jpeg", while OpenLayers will always request "jpg" files.
> Jachym
> Paul Spencer píše v Čt 25. 10. 2007 v 08:49 -0400:
>> Jachym,
>> if I understand it correctly, the image saved on disk has an
>> extension of .jpg while the mime type returned by the web server with
>> a JPEG image is image/jpeg. So the code is fine and is doing the
>> right thing. You just need to specify the correct extension in
>> OpenLayers (either 'jpg' or 'jpeg' will do) and in TileCache config
>> (again, probably either will do).
>> Paul
>> On 25-Oct-07, at 7:57 AM, Jachym Cepicky wrote:
>>> Hi,
>>> in OpenLayers.Layer.Tilecache, around line 55, there is
>>> this.extension = (this.extension == 'jpeg') ? 'jpg' :
>>> this.extension;
>>> in tilecache/TileCache/Layer.py, around line 80, there is
>>> if extension.lower() == 'jpg': extension = 'jpeg' # MIME
>>> IMHO, it does not make sense, if I understand this well, you can
>>> never
>>> access JPEG TileCache from OpenLayers
>>> Do I understand it well?
>>> Thanks
>>> Jachym
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky at gmail.com
>>> URL: http://les-ejk.cz
>>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> Jachym Cepicky
More information about the Dev
