[OpenLayers-Dev] jpeg vs jpg
Paul Spencer
pspencer at dmsolutions.ca
Thu Oct 25 09:11:19 EDT 2007
Ok, I take that back :) I was looking at the PIL code and it takes
the extension (jpeg) as a format option but I hadn't considered the
case where you were not using PIL. But in either case, I now realize
the final image name is being created incorrectly regardless of
whether PIL is used or not.
Paul
On 25-Oct-07, at 9:08 AM, Christopher Schmidt wrote:
> On Thu, Oct 25, 2007 at 08:57:02AM -0400, Paul Spencer wrote:
>> No. TileCache saves the image with a .jpg extension but uses 'jpeg'
>> for the mime type of the returned content. The underlying library,
>> PIL, will do that automagically for you.
> No.
> 1. PIL is not neccesarily involved in transactions. It is only used
> with meta-tiling, so invoking the name of PIL here is irrelevant.
> 2. The last parts of the diskcache key are:
> "%03d.%s" % (int(tile.y) % 1000, tile.layer.extension)
> 3. The Layer class converts the extension:
> if extension.lower() == 'jpg': extension = 'jpeg' # MIME
> self.extension = extension.lower()
> Jachym is right. The Layer.TileCache is wrong.
> Regards,
> Christopher Schmidt
> MetaCarta
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
