[OpenLayers-Dev] alt or title text on Layer.Marker
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Oct 26 04:37:23 EDT 2007
not so bad, the labels are working for me (+1 for adding it to trunk),
but I would need something, which would appear on mouse over
I'll try to update your Labels.js, if you would not mind
cheers
Jachym
Ezequiel Gonzalez Rial píše v Čt 25. 10. 2007 v 10:03 -0300:
> Jachym,
> I've developed something arround that (Ticket #751) wich is not yet on
> the trunk, it's a label that apperars next to the marker (by css you
> can set it above, below or wherever you want), as it inheritance from
> marker you don't loose anything you have already coded.
> Best Regards,
> Ezequiel Gonzalez Rial (gonrial at gmail.com)
> 2007/10/25, Jachym Cepicky <jachym.cepicky at gmail.com>:
> > Hi,
> > maybe, it would be good to have option for OpenLayers.Layer.Marker,
> > which would enable displaying alt text of icons on mouse over. The alt
> > attribute could be e.g. Title of OL.Layer.Text
> > Is there such possibility, which would display alt or other attribute,
> > while moving with mouse over icon?
> > thanks
> > jachym
> > Jachym Cepicky
> > e-mail: jachym.cepicky at gmail.com
> > URL: http://les-ejk.cz
> > GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
Jachym Cepicky
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071026/1f0296dd/attachment.bin
More information about the Dev
