[OpenLayers-Dev] OSM tiles and other overlays simultaneously
Vladimir Elistratov
v_elistratov at rambler.ru
Tue Sep 4 07:43:47 EDT 2007
> If you want that, you want to set up your own tiles -- or use
>another
> service on the web which provides up to date, unprojected tiles.
> OSGeo used to host one of these, but I let it lapse after recent
> planet.osm troubles. I can take the time to set it up again -- then
> you'd just point to http://t1.hypercube.telascience.org/tiles? ,
>with a
> layer of osm-4326, which would allow you to use tiles that are
> compatible with all the 'unprojected' services out there.
> If I set it up again, would you use it? If so, I can set it up
>again.
I'd like to use my own tiles since they will be used locally or in a
local network.
Is there a way to use them and all the 'unprojected' services out
there without installing a WMS server?
More information about the Dev
