[OpenLayers-Dev] OpenLayers.Format.KML.write()
Damien Corpataux
damien.corpataux at camptocamp.com
Tue Sep 4 11:21:53 EDT 2007
Thanks!
I think you mean unit tests... Glurp, I never played around with
testanotherway. Although I'm interested in doing it when I get to have a
little time, here is the test code I ran in firebug, using the
openlayers/examples/vector-features.html example:
---8<-------------------------------------------------------------------
var kml = new OpenLayers.Format.KML();
var kmlOut = kml.write(map.layers[1].features);
kmlOut;
map.layers[1].eraseFeatures(map.layers[1].features);
map.layers[1].features = [];
var features = kml.read(kmlOut);
features;
map.layers[1].addFeatures(features);
Cheers,
Damien
Christopher Schmidt wrote:
> On Tue, Sep 04, 2007 at 04:28:52PM +0200, Damien Corpataux wrote:
>> Hi Tim,
>> I just posted a patch on ticket #927. The patch suits the requirements:
>> - KML extends XML
>> - XML class methods are used for XML manipulation
>> - tested on FF2/Linux and IE7
>> - KML.write() returns a string (using XML.write())
>> - GGE import of OL exported KML is working, and vice-versa
> Looks pretty good. Any chance you could write some tests for KML.write()
> -- just a few simple ones, to confirm it works?
> Regards,
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070904/7a5a19c1/attachment.html
More information about the Dev
