[OpenLayers-Dev] OpenLayers.Format.KML.write()
Damien Corpataux damien.corpataux at camptocamp.com
Wed Sep 5 06:27:09 EDT 2007
Hi Christopher,
Thanks for the stub! It got me into writing the tests (very quick).
Everything's fine on ff2, but a problem occurs on IE7 (only when running
the tests, not on using the component within OL).
I put all the information and patch into the ticket, which I now wonder
whether it's a good idea, http://trac.openlayers.org/ticket/927#comment:5
Anybody might have ran into a similar problem with test.anotherway?
Cheers,
Damien
Christopher Schmidt wrote:
> On Tue, Sep 04, 2007 at 05:21:53PM +0200, Damien Corpataux wrote:
>> Thanks!
>> I think you mean unit tests... Glurp, I never played around with
>> testanotherway. Although I'm interested in doing it when I get to have a
>> little time, here is the test code I ran in firebug, using the
>> openlayers/examples/vector-features.html example:
> Okay, I've put together a stub for you in the tests/Format/test_KML.html
> file. What I would do here is very similar to what you have below:
>  * Create a KML parser.
>  * Create a feature -- point, line, polygon, whatever.
>  * In Firebug or elsewhere, create a text string which you can copy
>    paste with the expected output KML: set that as the expectedOut
>    variable.
>  * Create kmlOut against that feature:
>    kmlOut = kml.write([myFeature]);
>  * Test that expectedOut matches KML Out:
>     t.eq(expectedOut, kmlOut, "KML output matches given point feature");
>  * If you feel up to it, add a test to write, which reads the output
>    KML (as below) and test things like:
>     t.eq(outputFeatures.length, 1, "Got correct number of features
>                                     back");
>     t.eq(outputFeatures[0].geometry.CLASS_NAME, "OpenLayers.Geometry.Point",
>                       "Correct geom type returned.");
> etc.
> If you don't get a chance, I'll bang something out soon, since we're
> trying not to shove things in without at least some tests -- but thanks
> for the patch regardless!
>> ---8<-------------------------------------------------------------------
>> var kml = new OpenLayers.Format.KML();
>> var kmlOut = kml.write(map.layers[1].features);
>> map.layers[1].eraseFeatures(map.layers[1].features);
>> map.layers[1].features = [];
>> var features = kml.read(kmlOut);
>> features;
>> map.layers[1].addFeatures(features);
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070905/7848d915/attachment.html
More information about the Dev mailing list
