[OpenLayers-Dev] improvements in the OpenLayers project's licenses
John R. Frank john.frank at metacarta.com
Thu Sep 13 06:32:03 EDT 2007
Dear OpenLayers Community,
We intend to make these changes in a few days.  If you have any questions
or comments, please direct them to users at openlayers.org
Over the past few months, the OpenLayers PSC has discussed a couple issues
in project licensing.  One issue that motivated this is an inconsistency
in the way we were treating sandboxes.  We intend for sandboxes to be easy
places for people to drop code before it has been groomed for
distribution, which could be before a CLA has been signed.  Currently, the
repository-license.txt implies that a CLA has been signed.  In fact,
currently, the sandboxes are *un*licensed.  The changes below fix this and
improve the overall repository licensing setup.  One of the foss4g
discussion topics can be how to make sandboxes licensable -- CRS is
carrying this on his list of things to discuss.
The PSC has voted to adopt the following specific improvements, which
serve to clarify ownership and move OpenLayers closer to OSGEO graduation.
1) Reorganize the directories and license files in SVN as follows:
/sandbox/
/trunk/
/branches/
/project/website/         * moved from /trunk
/tags/
/sandbox-license.txt      * see below
/repository-license.txt   * also copied into /trunk/openlayers/.
/release-license.txt
2) The current repository-license.txt has a preamble sentence that says
that it covers the sandboxes.  This is not the intent.  The attached
sandbox-license.txt says what we intend.
3) The current repository-license.txt explicitly references MetaCarta.
We intend to replace it with the Clear BSD [1], which is better.  In
addition to replacing the old repository-license with the Clear BSD, we
intend to change the first sentence to say "This license applies to all
code and content in the 'branches', 'trunk', and 'project' directories of
the Openlayers code repository at svn.openlayers.org"
4) As described on the page about the Clear BSD [1], the current CLAs are
not as explicit about patent rights as one might like, so we intend to
replace the current CLAs with those.  In case you're curious, MetaCarta is
now using the Clear BSD and these CLAs on FeatureServer and TileCache.
5) Similarly, we intend to change the release-license.txt sentence to say
"This license applies to official code releases of the OpenLayers project,
which are stored in svn.openlayers.org/tags/ and provided in archive form
from www.openlayers.org"
Yours,
John Frank on behalf of the OpenLayers PSC
[1]  http://labs.metacarta.com/license-explanation.html
These statements apply to all code and content in the sandbox
directories inside the OpenLayers code repository in the
subdirectories below svn.openlayers.org/sandbox/
Each sandbox directory contains content owned or licensed by the
submitter.  The submitter may be able to grant you rights to use or
redistribute material from these directories.  You must obtain such
permissions directly from them.
Neither the OpenLayers project nor its maintainer (MetaCarta, Inc.)
maintain or own the material in the sandboxes.  Nobody grants you any
rights nor makes any express or implied warranties of any kind
regarding this material.
Before material from a sandbox can be moved into another part of this
SVN repository or become part of an OpenLayers release, the owner must
sign a Contributor License Agreement and announce the contribution on
the dev at openlayers.org list.  After that, the project maintainers will
arrange to move the material out of the sandbox to an appropriate
location from which others may use or redistribute the material in
accordance with OpenLayers project licensing.
IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
More information about the Dev mailing list
