[OpenLayers-Dev] Fwd: [OSGeo-Discuss] FOSS4G CodeSprint are you
ready?
Christopher Schmidt
crschmidt at metacarta.com
Tue Sep 18 12:52:26 EDT 2007
On Tue, Sep 18, 2007 at 11:54:40AM -0400, Mike Adair wrote:
> How about:
> - add support for MapGuide OS layer type; this code is essentially ready
> to go, I just need to create a ticket and a patch.
Adding things like new layers is grunt work that is probably best done
outside the confrence setting if the code is largely complete: Unless
I'm mistaken, there are (for example) no tests for the code. Things like
that are really easy for a single person to review outside the
conference setting, where things which require multiple people are
harder to hack through.
> - add support forr coordinate trasnformations as described previously
This is a much better target, and I'm in favor of it. I think that it
may make sense to try and hack out some preemptive plans during
something like the webmap BOF, as well.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
