[OpenLayers-Dev] Rule subclasses and 2.6
Christopher Schmidt
crschmidt at metacarta.com
Sat Apr 5 14:57:31 EDT 2008
On Sat, Apr 05, 2008 at 11:13:31AM -0600, Tim Schaub wrote:
> The OpenLayers.Rule class comes from the sld:Rule element. A rule in
> SLD has optional constraints on scale (sld:MinScaleDenominator and
> sld:MaxScaleDenominator), typically has symbolizers (for Point, Line,
> Polygon, etc), and optionally has an ogc:Filter element.
Right.
> In the Filter Encoding spec (where you find the description of
> ogc:Filter elements), there are a number of types of filters. These
> include comparison filters, feature id filters, and logical filters. In
> OpenLayers (currently) the subclasses of OpenLayers.Rule map directly to
> these types of ogc:Filter.
Right.
> The problem is not only one of naming. An sld:Rule *has* an ogc:Filter.
> So a rule can have a feature id filter for example. In OpenLayers,
> an OpenLayers.Rule.FeatureId *is* a rule.
Sure. It's a combination of the Filter and Rule into a single object for
convenience, right? There's no replacement for
OpenLayers.Rule.FeatureID that wouldn't do the same thing the current
one does, is there?
> The difference is that rules have things like scale constraints and
> symbolizers. Filters do not have scale constraints and symbolizers. A
> filter is the child of a rule. A filter is not a rule.
Understood. So currently (as far as I understand it), we have Rule,
which encompasses Rule + Filter, and in the future, we could make the
seperation into Rule and Filter explicit: So Rule.FeatureID would
(internally) create a Filter.FeatureID with the properties that are
specified in the filter.
> So, OpenLayers.Rule.FeatureId would become OpenLayers.Filter.FeatureId.
Sort of, I think? OpenLayers.Rule.FeatureId would become OpenLayers.Rule
+ OpenLayers.Filter.FeatureId?
> This filter could be used for more than just styling - it could, for
> example, be serialized and used in a WFS query. This has nothing to do
> with styling.
Agreed. Filters are valuable.
> So yes, your cambridge example would break in the future. Instead you
> would do something like:
> var rule = new OpenLayers.Rule({
> symbolizer: {"Point": {"fillColor": "fuchsia"}},
> filter: new OpenLayers.Filter.Comparison({
> type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
> property: "Population",
> value: 10000
Alternatively, we add Filters, and make Rule subclasses a convenience
method that takes everything but the Rule-specific properties and passes
them onto the Filter?
> filter: new OpenLayers.Filter.Logical({
> type: OpenLayers.Filter.Logical.AND,
> filters: [
> type: OpenLayers.Filter.Comparison.LESS_THAN,
> value: 100000,
> type: OpenLayers.Filter.Comparison.GREATER_THAN,
> value: 0,
> The difference is that rules have symbolizers and a filter (optionally).
> Filters do not have symbolizers. A logical filter has child filters.
Right. To me, this doesn't indicate that we should get rid of
Rule.FeatureID: instead, that we should make it a wrapper around
Rule+Filter.
> My question was whether we wanted to
> 1) change this before 2.6, or
> 2) change this after 2.6.
Well, my position is "Neither": A rule is a combination of symbolizer +
Filters. The only thing is that right now, we define the filter
properties directly in the creation of the Rule, and we can instead use
those properties to create Filters in the future.
It seems like option 1) above sets us back another month in the process,
because we need to abandon the RC at that point, and move back to step 1
in the release process: The entire point of an RC is "We think that if
there are no bugs, we can ship this". Perhaps this concept hasn't been
made clear enough in our discussions in the past: I had assumed that "no
non-regression changes after we hit RC" was obvious, but it's possible
that meaning has not actually been stated.
So, I'm a big -1 on changing to Rules and Filters before 2.6.
> If we change after 2.6, then we decide whether to wait for 3.0 or
> whether to release with the rule subclasses as not part of the API
> (subject to change).
I'm -0 on removing them from the API, since we then move them out of our
documentation and examples, and they become for most intents and
purposes unusable until 2.7. (Not having them in the examples being the
biggest blocker to people actually using them, I think.)
"Wait for 3.0" is a possibility, I guess, but I'd like to understand why
we can't provide Rule.FeatureId as a convenience method: is there
something that's likely to confuse users about it? I guess I'm -0 on
removing Rule subclasses even in 3.0, simply because doing so requires
an even deeper understanding of the underlying aspects of the building
blocks than I think we need to force users to have...
> I'm happy to write up a patch if we want to do this before 2.6 (which I
> do of course*).
If you had said all this 4 weeks ago, I would have said "write a patch
for 2.6, but I'd prefer to leave Rule subclasses as convenience
methods going forward."
Today, I'll say "I prefer to leave the Rule subclasses as convenience
methods going forward; because of that, we can skip the patch."
If I'm lonely in my position, then I'm willing to accept that we
should pull Rules from the API for this release, grudgingly.
> * In the future, I'm also in favor of branching in advance of a release
> so we don't release brand spanking new features with unstable interfaces.
I understand that this is likely led in large part by the recent style
work that TOPP has put in, but prior to that, the last commit to rules
was in early February... and prior to *that*, the last functional
change to rules was the initial commit in mid December. At what point
would branching early have helped? Was it known in December that someone
was going to be working seriously on SLD Styles/Rules/Filters in April?
If so, would that have changed our release plan for the features?
Maintaining stable APIs hasn't actually been that painful, I don't
think. There's extra code, yes. But I don't see how that extra code
hurts the end product. We don't spend much of our time supporting
deprecated APIs: even ones that don't have direct replacements are
pretty much abandoned by most users. (How many users still use
MouseToolbar instead of NavToolbar, despite the fact that the former has
functionality that the latter doesn't?) Have we really avoided many
changes because backwards compatibility? Or just made our development
slightly more complex because of it?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
