[OpenLayers-Dev] OpenLayers performance
Christopher Schmidt crschmidt at metacarta.com
Mon Apr 7 16:14:16 EDT 2008
On Mon, Apr 07, 2008 at 09:35:50PM +0200, tomas.novotny at tmapy.cz wrote:
> The link to OL example Guillaume posted is also the case I wrote about.
> Let's try it (http://www.openlayers.org/dev/examples/fullScreen.html).
> Please switch off overlay for fair-play and zoom in the map. Then make a
> few large circles with map using mouse. Try the same with GM. And don't
> try to tell me you have the same feeling (at least in FF 2 and IE7).
Well, I hate to be the bearer of bad news, but on my browser on my
computer, they feel about the same.
This is backed up, to some extent, by empirical evidence: using a
stopwatch, I dragged each map around in circles, clockwise, for 5
seconds, with the Firebug profiler turned on for each.
OpenLayers: 944.26ms, 57342 calls
Google Maps: 820.147ms, 44818 calls
So, it appears that OpenLayers could be said, based on the empirical
evidence on my browser, to be about 15% slower than Google Maps: given
the limited scope of the specific test here, I would say that's not
really a big enough difference to complain about.
Interestingly enough, this is apparently a significant change from 2.5:
OpenLayers 2.5: 1469.714ms, 138497 calls
So, we've gained a 35% performance improvement without even trying. Not
bad.
> And I've made lot of such tests with same result.
> I have absolutely nothing personal against OL, I really like them from
> many points of view. I also understand and agree with Christopher when he
> talks about freedom of influencing OL code. But if I try to solve that
> panning problem I would do so significant change that I would be really
> worried about the rest of the code.
Well, without understanding what is behaving slowly for you, it's hard
for anyone to fix it, but as I said, there is no intention to be slow,
and I don't see any serious evidence to indicate that OL is any worse in
this case than any other mapping API on my platform of choice.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
