[OpenLayers-Dev] Project this morning: Canvas Renderer
    Christopher Schmidt
    crschmidt at metacarta.com
    Sat Apr 12 11:54:53 EDT 2008
http://trac.openlayers.org/ticket/1512 has this morning's project, a
canvas-based Renderer for OpenLayers vector layers.
For comparison:
  * Canvas: http://crschmidt.net/mapping/choropleth-canvas.html
  * SVG: http://crschmidt.net/mapping/choropleth.html
(If this isn't available,
http://dev.openlayers.org/sandbox/crschmidt/canvas-renderer/examples/canvas-renderer.html
is/should be.)
In Firefox 2, there will probably be an obvious difference in rendering
speed. (there is also an obvious difference in functionality: the former
has no hover-select control, for performance reasons.)
>From the ticket:
It implements feature selection by looping over its internal list of
features, and doing intersection queries. Depending on the browser, this
may or may not be reasonable. One thing that this behavior suggests is
that the standard Feature Handler should perhaps be informed whether it
is being used as a 'hover' handler: if it isn't, it shouldn't bother
doing the (now somewhat expensive) getFeatureIdFromEvent check on
mousemove as it currently does.
For browsing somewhat static vector data, this Renderer is quite
effective, especially for browsers where SVG support is less fast: FF2,
for example, gets to be much more usable on whole-world country borders
maps that are currently being tossed about.
Includes support for stroke/fill width/color/opacity, externalGraphic,
point/line/linearring/polygon and collections thereof.
I've tested it in Safari 3.1, FF2, and Opera 9.5 on Mac. (IE still falls
back to the VML renderer in all situations so far as I'm aware.)
I find the most difference in Firefox 2, where the large DOM created by
the SVG document tends to make interacting with the map a painful
process. Of note, the entire canvas redraws on zoom/dragend/etc., so
there is a definite performance hit there, but even with 400 relatively
complex features, it's only approximately a half second to redraw all of
the polygons, which is pretty impressive, in my opinion.
The code is avaialble in #1512, or in the canvas-renderer sandbox, if
you're more comfortable with SVN than 'patch'.
http://svn.openlayers.org/sandbox/crschmidt/canvas-renderer/
Feedback gladly accepted.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
