[OpenLayers-Dev] vector behavior
Tim Schaub tschaub at openplans.org
Tue Apr 15 06:21:06 EDT 2008
Christopher Schmidt wrote:
> On Mon, Apr 14, 2008 at 05:46:47PM -0600, Tim Schaub wrote:
>> Hey-
>> Some may have already seen the proposal for new vector layer behavior.
>> http://trac.openlayers.org/wiki/Proposal/VectorBehavior
>> This week, I'll be working on implementing a bit of this new design.
>> I'm focussed on an AtomPub protocol, an Atom format, and a somewhat
>> smartish BBOX strategy.
> Thanks for the email letting us know what's up.
> Out of curiosity: some Protocols seem likely to be 'trapped' within a
> single Format. I'm assuming that you don't see any problem with that, so
> long as it is sufficiently documented. I'm asking only because the
> majority of protocols seem to clearly be in a position where they'll be
> able to cope with many formats -- WFS read support, AtomPub support,
> etc. -- while a minority -- ESRI-REST, WFS-T/write, etc. -- are tied to
> a specific Format. Does this make sense? Is a format-specific protocol
> still a protocol? (I think yes.)
Yeah, this seems unavoidable.
After a bit of discussion with Eric this morning, we came up with a
cleaner design.  A protocol knows only about format (not layer).  A
strategy knows about layer.  A strategy can be used to trigger requests
with a format - and the strategy supplies callbacks.  In the case of
read, the strategy callback expects to receive a list of features.
All a moving target at this point.  Good to have discussion on what
things should look like.
Tim
>> I've started putting stuff up in an "almanac" sandbox.  The one example
>> that shows it wired together is not that impressive - but it represents
>> a new design for giving vector layers behavior.
>> http://dev.openlayers.org/sandbox/topp/almanac/examples/vector2.html
>> I appreciate any ideas on the work.  I've got a deadline to get this
>> working by next Monday - so it will be hasty work for a while.
>> http://trac.openlayers.org/log/sandbox/topp/almanac/
> I'm assuming that in the meantime you'd primarily like committing to be
> held to topp people without prior discussion: I'm hacking a bit in SVK,
> and when you guys pass your deadline, I hope to have some code
> (unrelated to your current work) to toss back in the sandbox, so looking
> forward to helping from afar in the meantime.
> Regards,
More information about the Dev mailing list
