[OpenLayers-Dev] mouse cursors
bartvde at osgis.nl
bartvde at osgis.nl
Wed Apr 23 08:38:53 EDT 2008
Yeah, I've seen that as well (also in FF2 on Windows and IE6 btw, at least
on my computer).
I could not find a workaround however to prevent this behaviour, i.e. when
changing the cursor from a url cursor to another url cursor, the default
cursor appears for a while in between.
Best regards,
Bart
On Wed, 23 Apr 2008 22:35:37 +1000, "Zac Spitzer" <zac.spitzer at gmail.com>
wrote:
> looks great in firefox, ie7 seems to "flutter" between dragging between
> the pointer cursor and the 'action' cursor
> On Wed, Apr 23, 2008 at 9:18 PM, <bartvde at osgis.nl> wrote:
>> Hi list,
>> I've been working a bit on mouse cursors in OL, and would like to
> request
>> some feedback on the current approach.
>> I've got an example up in my sandbox:
>> http://dev.openlayers.org/sandbox/bartvde/cursor/examples/cursor.html
>> And I've added a very preliminary patch to ticket1484:
>> http://trac.openlayers.org/attachment/ticket/1484/ticket1484.patch
>> I'll try and outline my approach a bit. The most difficult decision I
> found
>> was whether or not to use css. I find it quite a bit of overhead to
> make
>> css classes for all possible cursor combinations. In my case I would
> need
>> the following classes (looks already quite cumbersome to me):
>> .olControlZoomBoxCursor
>> .olControlZoomBoxOutCursor
>> .olControlDragPanCursor
>> .olControlDragPanMouseupCursor
>> .olControlDragPanMousedownCursor
>> etc.? As you can see, even control properties (like the out property
> for
>> ZoomBox) come into play, so we would need something like a cursorClass
>> property for people to override the default class names. For the
> approach
>> to work, we would need them to start their names with the 'olControl'
>> prefix, otherwise we don't know which css classes are safe to remove
> from
>> the map div when e.g. a different control is activated (we cannot just
>> remove any css class from the map div, since people might have set
> stuff on
>> it, so we should remove all classes that start with 'olControl' or some
>> similar approach). This can be error-prone IMHO.
>> I did see there are some utility functions (like addClass, removeClass,
>> toggleClass) in topp's almanac sandbox which could be used.
>> Disadvantage ofcourse of my approach is that the mouse cursors cannot
>> easily be altered by non-programmers, but I wonder how often a chosen
>> cursor approach will change in a project.
>> If people feel strongly that css is the way to go though, I can change
> the
>> code to add and remove css classes on the map div.
>> What I've done is briefly:
>> * add a cursor property on the Control class, which is set on the map
> div
>> when the control is activated
>> * add a cursors property (array) on the Handler class, which makes it
>> possible to set cursors on the map div in different functions of a
> Handler
>> (like mousedown). For now I've only implemented mousedown and mouseup
> in
>> the Drag Handler as an example.
>> I think the example and the patch tells the rest of the story best.
>> Feedback very much welcome. TIA.
>> Best regards,
>> Bart
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
More information about the Dev
