[OpenLayers-Dev] Know of any offline datasets compatible with
OpenLayers?
danguyf
meat_catch at p0mi.com
Wed Apr 23 10:46:37 EDT 2008
Christopher Schmidt-4 wrote:
> On Fri, Nov 23, 2007 at 09:07:47AM +0000, Ian Mayo wrote:
>> > Totally offline data can be easy... if it is small or your storage is
>> > big. Storing the top 7 levels of the vmap0 dataset as tiles
>> > is something like 200MB of data. Depending what you actually want to
>> do,
>> > this might be useful or not -- but I'm almost positive that it's going
>> > to be more useful than trying to actually draw the world as a vector.
>> I presume you're describing the use of a standalone mapping server to
>> support the OpenLayer instance.
> Nope. I've done it in the past (http://labs.metacarta.com/on-a-stick/)
> by pre-generating a cache using TileCache, then using the
> Layer.TileCache class to access it.
I tried out v1.0, but I don't see the cache and, when attempting to use it
offline, the tiles are all missing. Please advise. Thank you.
d.
View this message in context: http://www.nabble.com/Know-of-any-offline-datasets-compatible-with-OpenLayers--tp13903025p16834640.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
