[OpenLayers-Dev] Features added to vector layer don't rescale
when map extent changes
Christopher Schmidt
crschmidt at metacarta.com
Wed Aug 13 09:12:41 EDT 2008
On Tue, Aug 12, 2008 at 11:40:25PM -0400, David Fuhry wrote:
> I add a new OpenLayers.Layer.Vector to my map, several
> OpenLayers.Feature.Vectors to that layer using
> vector_layer.drawFeature(), then call map.zoomToExtent(). When the map
> is zoomed, the vector features remain in a static state, rendered for
> the original extent, not the new zoomed extent.
> I would like the features to be rescaled when the map is zoomed /
> panned. I've tried passing { isFixed: false } to the
> OpenLayers.Layer.Vector constructor without success. Is this not an
> envisioned use case of a OpenLayers.Layer.Vector layer with manually
> added features?
No, it's simply that this seems entirely wrong. Vectors should never
continue to display in the same place after zooming: at worst, they
might disappear, but they should never be *wrong*.
If you look at http://crschmidt.net/mapping/vectors.html , does it do
what you want? If you look at it, can you see what you're doing
differently that results in the different behavior?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
