[OpenLayers-Dev] vector labels - almost there!
Mark Nine
mbailen at usgs.gov
Wed Aug 20 14:27:55 EDT 2008
I dug a little more into this problem. The line that is erroring out is in
this file:
http://dev.openlayers.org/sandbox/camptocamp/text/lib/OpenLayers/Renderer/VML.js
in the method drawText():
span.innerHTML = style.label;
textbox.appendChild(span);
The error occurs on the appendChild. Seems this is a common problem with IE
when dynamically creating scripts or styles (or spans?) and using innerHTML.
Unsure how to fix it. The documented fixes haven't worked for me.
Mark Nine wrote:
> Hi,
> I was wondering if there was any more progress on Vector Labels?
> I have gotten it too work in Firefox, but now I am having problems in IE7.
> When I try to add the feature (a point with a label defined), IE7
> complains about an unexpected call to a method or property access.
> Thanks
> Mark
View this message in context: http://www.nabble.com/vector-labels-tp16589123p19075418.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
