[OpenLayers-Dev] [OpenLayers-Commits] r5509 - in
trunk/openlayers: lib/OpenLayers lib/OpenLayers/Layer tests/Layer
Erik Uzureau
euzuro at gmail.com
Thu Aug 21 13:14:35 EDT 2008
http://trac.openlayers.org/ticket/1683
On Wed, Jan 9, 2008 at 7:52 PM, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> A comment related to this patch.
> The commit done here is very good... what i'm actually wondering about
> is the original setOpacity() function as defined on the
> OpenLayers.Layer object.
> Why are we doing DOMElement modifications at this level? the basic
> Layer object does not own images and should not know anything about
> them. just like this patch overrides setOpacity() to individually set
> the opacity of its markers, so should the Grid layer iterate through
> its tiles and call setOpacity() on each of them.
> no?
> ---------- Forwarded message ----------
> From: commits at openlayers.org <commits at openlayers.org>
> Date: Dec 19, 2007 9:00 AM
> Subject: [OpenLayers-Commits] r5509 - in trunk/openlayers:
> To: commits at openlayers.org
> Author: fredj
> Date: 2007-12-19 10:00:49 -0500 (Wed, 19 Dec 2007)
> New Revision: 5509
> Modified:
> trunk/openlayers/lib/OpenLayers/Layer.js
> trunk/openlayers/lib/OpenLayers/Layer/Markers.js
> trunk/openlayers/tests/Layer/test_Markers.html
> Log:
> OpenLayers.Layer.Markers - propagate layer's opacity to the markers. Thanks
> ahughes for the bug report and crschmidt for review and advices. (Closes #1114)
> Modified: trunk/openlayers/lib/OpenLayers/Layer/Markers.js
> --- trunk/openlayers/lib/OpenLayers/Layer/Markers.js 2007-12-19
> 12:51:06 UTC (rev 5508)
> +++ trunk/openlayers/lib/OpenLayers/Layer/Markers.js 2007-12-19
> 15:00:49 UTC (rev 5509)
> @@ -57,7 +57,22 @@
> OpenLayers.Layer.prototype.destroy.apply(this, arguments);
> + * APIMethod: setOpacity
> + * Sets the opacity for all the markers.
> + * Parameter:
> + * opacity - {Float}
> + setOpacity: function(opacity) {
> + if (opacity != this.opacity) {
> + this.opacity = opacity;
> + for (var i = 0; i < this.markers.length; i++) {
> + this.markers[i].setOpacity(this.opacity);
> * Method: moveTo
> @@ -85,6 +100,11 @@
> addMarker: function(marker) {
> this.markers.push(marker);
> + if (this.opacity != null) {
> + marker.setOpacity(this.opacity);
> if (this.map && this.map.getExtent()) {
> marker.map = this.map;
> this.drawMarker(marker);
> Modified: trunk/openlayers/lib/OpenLayers/Layer.js
> --- trunk/openlayers/lib/OpenLayers/Layer.js 2007-12-19 12:51:06
> UTC (rev 5508)
> +++ trunk/openlayers/lib/OpenLayers/Layer.js 2007-12-19 15:00:49
> UTC (rev 5509)
> @@ -29,6 +29,12 @@
> div: null,
> + * Property: opacity
> + * {Float} The layer's opacity. Float number between 0.0 and 1.0.
> + opacity: null,
> * Constant: EVENT_TYPES
> * {Array(String)} Supported application event types
> Modified: trunk/openlayers/tests/Layer/test_Markers.html
> --- trunk/openlayers/tests/Layer/test_Markers.html 2007-12-19
> +++ trunk/openlayers/tests/Layer/test_Markers.html 2007-12-19
> @@ -77,7 +77,33 @@
> + function test_Layer_Markers_setOpacity(t) {
> + t.plan(1);
> + layer = new OpenLayers.Layer.Markers('Test Layer');
> + var opacity = 0.1234;
> + for (var i = 0; i < 12; i++) {
> + layer.addMarker(new OpenLayers.Marker(new
> OpenLayers.LonLat(0,0), new OpenLayers.Icon()));
> + layer.setOpacity(opacity);
> + for (var i = 0; i < 4; i++) {
> + var itWorks = false;
> + for (var i = 0; i < layer.markers.length; i++) {
> + itWorks =
> parseFloat(layer.markers[i].icon.imageDiv.style.opacity) == opacity;
> + if (!itWorks) {
> + break;
> + t.ok(itWorks, "setOpacity change markers opacity");
> </script>
> </head>
> <body>
> Commits mailing list
> Commits at openlayers.org
> http://openlayers.org/mailman/listinfo/commits
More information about the Dev
