[OpenLayers-Dev] adding markers with popups as features.
Fred Arters
fred at monkeytroy.com
Thu Aug 21 17:51:42 EDT 2008
Thanks for the advice. I have it working now using Vector with an
externalSymbol style as you suggest. Seems to work fine and a bit
cleaner as I don't have to add a separate pop up and marker for each
feature. Thanks.
Though I do have a question... what would be the correct way to then
move one of my marker as a vector? For a feature all I had to do was
set the lonlat attribute and refresh the layer and it moved.. but
that doesn't seem to work with a Vector. The documentation says there
is a move function but it fails and looking at the code does not seem
to be there.
I didn't see it but is there an example that does this too?
-Fred
On Aug 21, 2008, at 12:56 AM, Eric Lemoine wrote:
> Hi. Yes, the new way is to use Layer.Vector for markers. To render
> points as markers the externalSymbol style property must be passed to
> the layer, see the examples to understand how to do it. To select
> features and display a popup you can use the SelectFeature control and
> register a featureselected event listener to the layer events. This is
> a rough description, look at the API doc and the examples, and come
> back with specific questions if needed. Hope this helps. Cheers. Eric
> 2008/8/20, Fred Arters <fred at monkeytroy.com>:
>> I need to be able to dynamically create and add markers to my map,
>> each with it's own pop up. Had some trouble getting it to work. I
>> could create markers and remove them and I could handle an event
>> for a
>> marker but the examples really directly associated contents of a
>> popup
>> with one method that was tied to one marker. So adding several
>> markers with their own pop up details dynamically from a function was
>> not as easy or as obvious as I thought.
>> The examples were not really helping me with what I needed. There
>> are examples to create markers and examples to manually create
>> markers
>> with popups but with hard-coded content in the pop ups. Some of the
>> examples I found based on xml files didn't really apply either,
>> though
>> in the future they may.
>> I came up with this and it works.. so here it is for anyone else
>> needing the same kind of thing.
>> function addMarker(pLon, pLat, pPopUpText) {
>> // setup the icon
>> var size = new OpenLayers.Size(15, 22);
>> var offset = new OpenLayers.Pixel(-(size.w / 2), -size.h);
>> var theIcon = theIcon = new OpenLayers.Icon('img/marker.png',
>> size, offset);
>> // set the popup size.. static for now.
>> var theSize = new OpenLayers.Size(350, 200);
>> // create a feature.
>> var feature = new OpenLayers.Feature( featureLayer, new
>> OpenLayers.LonLat(pLon, pLat),
>> {icon: theIcon, popupSize: theSize, popupContentHTML:
>> pPopUpText});
>> // create the marker and popup
>> feature.createMarker();
>> feature.createPopup(true);
>> // hide the popup to start.
>> feature.popup.hide();
>> // add the popup and marker to the map.
>> theMap.addPopup(feature.popup);
>> markerLayer.addMarker(feature.marker);
>> // toggle the popup.
>> feature.marker.events.register("mousedown", feature, function
>> (evt) {
>> feature.popup.toggle();
>> OpenLayers.Event.stop(evt);
>> When you want to remove a marker you have to remove the marker from
>> the marker layer, destroy the pop up and then the feature.
>> Thoughts on this?
>> Works really well for me but is there a more appropriate way to use
>> the Feature for creating markers and associated popups? Looks like
>> Vector will become the way to do it in the future but right now the
>> createMarker and createPopup methods for vector are just stubbed out
>> functions that return null.
>> -Fred
More information about the Dev
