[OpenLayers-Dev] How to add multiple measure geometry
Vidal, Antoni
antoni.vidal at icc.cat
Tue Dec 2 11:21:10 EST 2008
Hello,
The Measure example i OL 2.7 only add a geometry on the map. If you draw a line and then you draw another line or a polygon, the first geometry is deleted. I would like to change this behavior and to maintain geometries drawn by user.
Any example or idea will be thankful.
Thank's in advance
Antoni Vidal
Institut Cartogràfic de Catalunya Tel: +34-93 567 1500 Ext. 3228
Parc de Montjuïc Fax: +34-93 567 1567
08038 Barcelona http://www.icc.cat <http://www.icc.cat/>
Spain
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081202/4c270291/attachment.html
More information about the Dev
