[OpenLayers-Dev] baseLayers switcher control
(GMapTypeControl-like)
Pierre GIRAUD
bluecarto at gmail.com
Thu Dec 4 08:15:08 EST 2008
I had no answer so I dove into it myself.
The first attempt can be seen in a specific sandbox [1].
It needs more work on the css.
Is this something we would want into trunk or as an addin ?
Feedbacks accepted.
Pierre
[1] http://dev.openlayers.org/sandbox/camptocamp/maptypepanel/openlayers/examples/mapTypePanel.html
On Wed, Dec 3, 2008 at 9:54 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> Hi all,
> I'm wondering if someone has an example of application or code
> implementing a control that behaves like the GMapTypeControl, eg
> adding toogle buttons on the top right of the map to switch between
> the map baselayers.
> I found this (very) old ticket.
> http://trac.openlayers.org/ticket/497
> Regards,
> Pierre
More information about the Dev
