[OpenLayers-Dev] baseLayers switcher control
(GMapTypeControl-like)
Eric Lemoine
eric.c2c at gmail.com
Thu Dec 4 11:49:17 EST 2008
Hi Pierre
I'm also +1 on having such a control in the trunk.
And I must admit that I'm still confused with what should be a addin
as opposed to being added to trunk.
Eric
2008/12/4, Pierre GIRAUD <bluecarto at gmail.com>:
> I had no answer so I dove into it myself.
> The first attempt can be seen in a specific sandbox [1].
> It needs more work on the css.
> Is this something we would want into trunk or as an addin ?
> Feedbacks accepted.
> Pierre
> [1]
> http://dev.openlayers.org/sandbox/camptocamp/maptypepanel/openlayers/examples/mapTypePanel.html
> On Wed, Dec 3, 2008 at 9:54 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
>> Hi all,
>> I'm wondering if someone has an example of application or code
>> implementing a control that behaves like the GMapTypeControl, eg
>> adding toogle buttons on the top right of the map to switch between
>> the map baselayers.
>> I found this (very) old ticket.
>> http://trac.openlayers.org/ticket/497
>> Regards,
>> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
