[OpenLayers-Dev] square nodes not rendering.
Garthanos
lancelot at inetnebr.com
Wed Dec 10 13:26:20 EST 2008
Moving this to the developers list, in part because its a bit obscure for
general
users to care about.
Tim Schaub-3 wrote:
Hey-
Lance Dyas wrote:
> I also want to customize the nodes (really just draw smaller squares
> instead of circles for the nodes)
See http://openlayers.org/dev/examples/measure.html
You can use any well-known name for a point (where well-known is
determined by the SLD spec).
Note that setting the style for a sketch handler is harder than it
should be - we should be using the temporary rendering intent of the
target layer's style map (see http://trac.openlayers.org/ticket/1634).
In the case of the measure control, there is no target layer - so you'd
still need to set the style as shown in the above example.
You'll have to adapt the code for your use case.
... [show rest of quote]
Thanks for the help I was able to implement this .. or atleast mostly
when the nodes are rectangles instead of circles however I seem
to have run in to a browser specific error..
To show the error draw a polygon it works as expected and the nodes
show up on compleation because it is selected and is active for editing
now erase it...
then draw a new one when it is finished it should show the nodes again
.. well it works in Internet Explorer but so far as I have tested not
anywhere else.
http://www.geospatialgateway.com/boxerrordemo.php
http://www.geospatialgateway.com/circledemo.php
with circle nodes it works as expected in all environments.
Should a bug be filled out or am I doing something wrong
or unexpected.
View this message in context: http://www.nabble.com/square-nodes-not-rendering.-tp20941089p20941089.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
