[OpenLayers-Dev] this.events is null error on map.destroy()
cjwhitmore
ceri.whitmore at hotmail.co.uk
Fri Dec 19 09:08:24 EST 2008
This is not correct. Instead, it should be ",this, testSwap".
and then in testSwap() I remove the event using the following:
map1.events.unregister('zoomend',this, testSwap);
If you change the above, this should work, but I can't be sure this is
actually your problem.
"I've made the suggested change, but get the same error message."
Can you share the line number that the error happens on, in a
non-singlefile build? What function it's being called from is important
to solving the problem.
"I've changed project to non-singlefile build.
Error is on line 1604:
this.events.triggerEvent("moveend");
in Map.js moveTo function.
It might be relevant that I take the latlon from the map before destroying
it. Which I transform, to center the new map in the different projection
thanks
Ceri"
View this message in context: http://www.nabble.com/this.events-is-null-error-on-map.destroy%28%29-tp21089492p21091875.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
