[OpenLayers-Dev] Custom control handlers
Alexandre Dube
adube at mapgears.com
Mon Dec 22 11:46:02 EST 2008
Alexandre Dube wrote:
> Hi devs,
> Controls have a "handler" property, but no "handlers". By default, in
> Controls.js, on activation, it checks this.handler and activate it.
> Which of these solutions is the best when you have multiple handlers
> for a new custom control :
> - register an on.("activate", function(){}) to activate its handlers
> - create a new activate function for the customized control that
> handles the handlers property
> - modify Controls.js, add a handlers property and modify the activate
> function to also check if handlers exist and activate all its handlers.
> The same goes for deactivation.
> Any tips ?
Thinking about it (please correct me if I'm wrong), the obvious answer
is the 2nd option : create a new activate function.
But, the 3rd option could also be good as a minor modification to OL
itself. What do you think ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
