[OpenLayers-Dev] IE cluster/protocol error - 'status' is null
or not an object
Andreas Hocevar
ahocevar at opengeo.org
Sat Dec 27 13:47:33 EST 2008
On Wed, Dec 10, 2008 at 12:02 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> HI, can please somebody confirm this? tnx
yes, I can confirm this. But unfortunately I have not figured out yet
what might be causing it.
Can you create a ticket (or point me to it if there is already one
that I missed)?
Thanks!
Andreas.
> On Thu, Dec 4, 2008 at 11:01 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>> Hi,
>> aaargh another IE(7) issue :( It occurs on IE when youre using
>> cluster strategy.
>> Its easily reproducible:
>> 1) open http://openlayers.org/dev/examples/strategy-cluster.html ->
>> everything shows up ok
>> 2) hit refresh ur enter the page again (hit enter on url address) -
>> cluster dont appear and attached error shows up ;(
>> 3) you can reload page again and again and again.....move/zoom map
>> hoping the features will load...... but nothing happens until you dont
>> clear ur IE cache and load page again!
>> I dont know if its a problem about protocol or cluster....
>> Please do you know how can this be quickly solved?
>> Thank you!
>> Regards,
>> Ivan Grcic
> Ivan Grcic
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
