[OpenLayers-Dev] new doc for OpenLayers
Christopher Schmidt
crschmidt at metacarta.com
Wed Dec 31 11:23:27 EST 2008
On Wed, Dec 31, 2008 at 03:34:08PM +0100, Jacolin wrote:
> Go back to OpenLayers, to add a Google base layer you have to add a ''layer'' object to your ''map'' object with the following method:
> .. code-block:: javascript
> new OpenLayers.Layer.Google(LayerName, options);
For this, I would say that we should have the general information
written in a general layers doc, like
http://trac.openlayers.org/wiki/Documentation/Dev/layers . This would
shorten the text to something more like:
For example:
var google = new OpenLayers.Layer.Google(
"Google Streets",
{type: G_NORMAL_MAP, 'sphericalMercator': true}
For more information on the options available to a Google Maps layer,
see the :ref:layer-google documentation.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
