[OpenLayers-Dev] Google layer and div resize: wrong config or bug?
Diego Guidi diegoguidi at gmail.com
Tue Feb 5 16:13:11 EST 2008
thanks for the suggest, and for your great work with openlayers.
On Feb 5, 2008 10:08 PM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Feb 05, 2008 at 09:44:35PM +0100, Diego Guidi wrote:
> > Sorry for the cryptic post, I try to explain my problem and tomorrow I
> > could send a sample code.
> > I have a "terrible" bug and i need to know if it's due to my mistake
> > or to a openlayers bug...
> > I'm creating a website (using openlayers, of course!) that publish WMS
> > data (from MapServer, but I'm using OpenLayers WMS layer).
> > This data is published over Google layers: I've prepared three layers
> > for satellite, maps, and hybrid google data.
> > So when i use my website, the layerswitcher control shows three map
> > data (from google) and a bunch of overlays.
> > All works well (sorry, all works GREAT!), except...
> > I'm using also ExtJS for create a flexible layout (something like
> > this: http://extjs.com/deploy/dev/examples/feed-viewer/view.html),
> > with a center div for openlayers and a right panel for additional
> > data: the panel size is modifiable with a splitter... and here are the
> > problems :(
> > When i resize the splitter (and, i suppose, the center div size
> > changes) the visible layers (one from google, and my data from WMS)
> > are sized correctly, but when i try to show another basemap from
> > google all the images are moved; looks like the tiles from google are
> > in a wrong position, moved in the upper-left corner from a size that
> > is not comparable to splitter move (i.e: if i move the splitter for 10
> > pixels or 200 pixels, the layer movement looks the same).
> > This problem is with IE7 and Firefox 2.0 (the only browser that I've tested).
> > I think that the problem is not well explained, so tomorrow i could
> > try to publish my website so anyone could see the problem abd look at
> > the source code.
> > Anyway, anyone has experienced my problem? Maybe should I simply call
> > map.updateSize()?
> Yes, this is a problem, it has been filed as a bug:
> http://trac.openlayers.org/ticket/830
> The patch there may be helpful. It looks unlikely at this point that a
> more general fix will make it into 2.6, but it is possible, through some
> other work that is being done.
> Regards,
> Christopher Schmidt
> MetaCarta
Diego Guidi
http://lacorrente.blogspot.com
More information about the Dev mailing list
