[OpenLayers-Dev] can't use tiff image
arjun dheer
dheer.arjun at gmail.com
Sun Feb 17 17:35:13 EST 2008
I am trying to use a Tiff image for display using openlayers. I tried to use
the following code. This code resembles the one in the
image-layer.htmlexample. The code is as follows:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>OpenLayers Image Layer Example</title>
<link rel="stylesheet" href="../theme/default/style.css" type="text/css"
<style type="text/css">
p {
width: 512px;
#map {
width: 512px;
height: 512px;
border: 1px solid gray;
</style>
<script src="../lib/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
map = new OpenLayers.Map('map');
var options = {numZoomLevels: 3};
var graphic = new OpenLayers.Layer.Image(
'City Lights',
'http://localhost/Aerial2005_1ft.tif',
* new OpenLayers.Bounds(-117.065, -32.740, -
117.000, 32.782),*
new OpenLayers.Size(5419, 4383),
options);
var jpl_wms = new OpenLayers.Layer.WMS( "NASA Global Mosaic",
"http://t1.hypercube.telascience.org/cgi-bin/landsat7",
{layers: "landsat7"}, options);
map.addLayers([graphic, jpl_wms]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()">
<h1 id="title">Image Layer Example</h1>
<div id="tags"></div>
<p id="shortdesc">
Demonstrate a single non-tiled image as a selectable base layer.
</p>
<div id="map"></div>
<div id="docs">
<p>
The "City Lights" layer above is created from a single web
accessible
image. If you construct it without any resolution related
options,
the layer will be given a single resolution based on the
extent/size.
Otherwise, it behaves much like a regular layer. This is
primarily
intended to be used in an overview map - where another layer
type
might not make a good overview.
</p>
</div>
</body>
</html>
The bounding box values were taken by taking an estimate of the lat long
values using google maps.
The image is not bieng displayed. I have also taken the easting northing
values of the image using ermapper software which are as follows:
left bottom: 637283.68 E
1860785.83 N
right top: 6312701.61 E
1865167.64 N
I have not yet converted these values into latlong values but will do so
once it is confirmed that I am headed in the right direction. Please help me
out as to what should I do to get the image displayed. Following are the
images shored in the htdocs folder. By the way, I am using Apache.
Please help me out.
Thanks,
Arjun
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080217/7f26b00c/attachment.html
More information about the Dev
