[OpenLayers-Dev] can't use tiff image
Andreas Hocevar
andreas.hocevar at gmail.com
Sun Feb 17 17:58:51 EST 2008
Arjun,
TIF images are not supported by most browsers.
arjun dheer wrote:
> Aerial2005_1ft.aux
> Aerial2005_1ft.rrd
> Aerial2005_1ft.tfw
> Aerial2005_1ft.tif
> Aerial2005_1ft.xml
The fileset you mention here is intended to be used as a data source for
a WMS Web Map Service, like GeoServer or Mapserver. Once you have
configured your WMS to use this data source, you can use it as
OpenLayers.Layer.WMS.
You might want to have a look at
http://geoserver.org/display/GEOSDOC/FOSS4G+2007+Workshop to get you
started with GeoServer and OpenLayers.
Regards,
Andreas.
More information about the Dev
