[OpenLayers-Dev] [Context.RWG] WMC, OWS Context,
and ContextCollection examples
Cameron Shorter
cameron.shorter at gmail.com
Wed Feb 20 19:08:14 EST 2008
Raj,
I like the idea of using a standard like Atom Collection. I can't
think of any implementation arguments for sticking with a
ContextCollection instead. AtomCollection seems to have the key fields
we require which are just Title and URL. Maybe a Description for a
Summary would be useful. But I don't see it as essential.
On Thu, Feb 21, 2008 at 10:35 AM, Raj Singh <rsingh at opengeospatial.org> wrote:
> If you drop the ContextCollection format, and adopt Atom Collection
> (which is the same format as an Atom feed) you might lose a little bit
> of Context-centric descriptive richness, but you will gain a lot:
> 1. ability to subscribe to Collections in your RSS reader (or for
> developers, ability to re-use your RSS reading code)
> 2. a "free" publishing and update standard
> 3. a "free" categorization scheme
> I attach a sample Atom Publishing Protocol (APP) service document for
> an OWS Context Collection (file: context_service_document.xml) and a
> sample Collection document (file: context_feed.xml).
> What do you think of this idea?
> Raj
> On Feb 19, 2008, at 5:21 PM, Cameron Shorter wrote:
> > There has been little talk about ContextCollection which is a simple
> > but effective way to list Context documents. It would be a useful
> > format to be returned from a Catalog query.
> > Files at:
> > http://svn.codehaus.org/mapbuilder/trunk/mapbuilder/examples
> > ContextCollection documents:
> > projDemo/Proj4jsMapExamples.xml
> > data/context/worldMapsCollection.xml
> > data/context/demoCollection.xml
> > timeSeries/timeSeriesCollection.xml
> > shipTracks/mapCollection.xml
> > Demis/mapCollection.xml
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Dev
