[OpenLayers-Dev] problem in InitResolutions?
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Feb 22 09:34:17 EST 2008
Hi list,
using latest trunk we are getting a problem in InitResolutions when we try
and add a layer with only a minScale and maxScale set.
The error is invalid array length and occurs at the following line:
confProps.resolutions = new Array(confProps.numZoomLevels);
If I look with Firebug numZoomLevels is null on the layer.
Any ideas what could be going wrong?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
More information about the Dev mailing list
