[OpenLayers-Dev] Cannot set Feature popupClass.
Leandro R
learonco at gmail.com
Mon Feb 25 13:21:45 EST 2008
Excellent !!!
Thank you very much.
2008/2/25, Erik Uzureau <euzuro at gmail.com>:
> OK sorry. just checked the documentation and in fact there is no
> 'options' parameter to the Feature class's constructor.
> So what you will have to do is:
> feature = new OpenLayers.Feature(layer, new OpenLayers.LonLat(lng,lat));
> feature.popupClass = OpenLayers.Popup;
> e
> On 2/25/08, Leandro R <learonco at gmail.com> wrote:
> > Hi
> > Thanks for your quick answer, but I had already tried that and did not
> work.
> > What else could be?
> > Thanks
> > > I think the problem here is that you are specifying the class in
> > > quotes as a string.
> > > It should just be:
> (lng,lat),
> > > > {popupClass:OpenLayers.Popup});
> > > ---e
> > > 2008/2/25 Leandro R <learonco at gmail.com>:
> > > > Hello all !!!
> > > > I need to change the popup class of a Feature object. I've tried to
> do
> > it as
> > > > the following, but it has not worked.
> (lng,lat),
> > > > {popupClass:'OpenLayers.Popup'});
> > > > I don't want to change that from the file Feature.js.
> > > > Can anyone help me?
> > > > Thanks
> > > > Leandro
> > > > _______________________________________________
> > > > Dev mailing list
> > > > Dev at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080225/c4fafec5/attachment.html
More information about the Dev
