[OpenLayers-Dev] Map id
Nils Weinander
nils.weinander at curalia.se
Wed Feb 27 02:23:12 EST 2008
Fr?d?ric Junod:
> This is not not a good idea to control the CSS by using the id
> of the html elements: they are generated by a "random" algorithm
> and can change. You have guarantees that the id will always be
> "OpenLayers.Map_2.
> Your graphics designer should use the CSS class instead.
This is indeed the case, but
Christopher Schmidt:
> And if (as is likely the case) the CSS class isn't set on the
> element in question, one should be set.
This is the reason for using the Id. The ZoomBar (the "ladder")
and the ZoomBar slider are represented by classless <div>-s with
a background image.
Nils Weinander | Systems Designer
Phone +46 (0)8 410 064 56
Mobile +46 (0)70 978 28 37
Curalia AB | www.curalia.se
Västmannagatan 15, 111 24 Stockholm, Sweden
More information about the Dev
