[OpenLayers-Dev] Personal 2.6 Goals
Eric Lemoine eric.c2c at gmail.com
Tue Jan 15 00:51:05 EST 2008
The one additional thing that I'd like to see in is the "vector
snapping" thing Pierre and fredj have been working on. I can
definitely help with making it trunk-ready. There's also Pierre's
vector symbols work, but I'll let him speak about that one...
Thanks,
Eric
On Jan 15, 2008 6:44 AM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> I have a couple of goals for 2.6 that are personal:
>  * OSM Format class
>  * Vector Layer reprojection.
> A distant third is the GPX format class.
> The former has been in a sandbox, and I've been using it, for a while.
> Mostly in demos, and I haven't done anything serious with it, but I
> would like to get it to trunk-readiness.
> This is important for continuing to improve the interactions OpenLayers
> can have with OSM.
> The latter is a more important requirement. Currently, we don't have
> support for reprojection of vector layers automatically, and we should
> be able to with the reprojection support. This involves doing a bit of
> logic on each layer that uses a format class to do reprojection
> automatically based on the setting on the layer and on the map.
> We've already seen a couple of cases of needing this. It will take a bit
> of doing, but probably not a ton -- I've already written the code once.
> Things that I'm hoping we can get into 2.6, but which I probably can't
> afford to put enough effort into on my own:
>  * Tweening code (Pierre)
>  * Animated Panning (Pierre)
>  * Zoom/transition code (Paul)
>  * Google Popups (tcolter? Maybe others?)
>  * Internationalization framework (madair)
>     (Translation is less important to me than having the framework in
>     place.)
> One thing I think it would be nice to have, if it's anywhere near
> 'complete' enough, is the SVG text rendering stuff... but I expect
> that's still far enough off that trying  for 2.6 is silly.
> So, in summary:
>  Things that I will write the code for:
>   #1273 (reprojection of layers), #1271 (OSM Format), Maybe #1272 (GPX)
>  Things I'd like to see, and will work to review once patches are
>  available:
>   #110 (animated panning), #933 (transition), #926 (Google Popups),
>   #109 (internationalization)
> I'm hoping that the people who are currently working on these four
> chunks of code can step up and say what they're currently stuck on, if
> anything, and what can be helped with to get these changes into trunk.
> The sooner this happens, the more likely it is to make it into 2.6.
> If anyone else has a list like this for their 2.6 wishlist, please
> share -- sharing ahead of time means that we can not spend so much time
> going back and forth in the meeting next week.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
