[OpenLayers-Dev] Personal 2.6 Goals
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Jan 15 02:05:57 EST 2008
Tim's been working on a few new things for us, and ofcourse it would be
great if they could make it into 2.6. Those things are:
1) WMC read/write support (ticket 100)
2) navigation history control (ticket 1240)
3) fractional zoom support (ticket 1243)
4) scalebar control (ticket 24)
5) measure control (ticket 1241)
Item 1 needs more work, but the others are close to trunk state.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Christopher Schmidt <crschmidt at metacarta.com>
Naar: dev at openlayers.org <dev at openlayers.org>
Onderwerp: [OpenLayers-Dev] Personal 2.6 Goals
Datum: 15/01/08 03:44
> I have a couple of goals for 2.6 that are personal:
> * OSM Format class
> * Vector Layer reprojection.
> A distant third is the GPX format class.
> The former has been in a sandbox, and I've been using it, for a while.
> Mostly in demos, and I haven't done anything serious with it, but I
> would like to get it to trunk-readiness.
> This is important for continuing to improve the interactions OpenLayers
> can have with OSM.
> The latter is a more important requirement. Currently, we don't have
> support for reprojection of vector layers automatically, and we should
> be able to with the reprojection support. This involves doing a bit of
> logic on each layer that uses a format class to do reprojection
> automatically based on the setting on the layer and on the map.
> We've already seen a couple of cases of needing this. It will take a bit
> of doing, but probably not a ton -- I've already written the code once.
> Things that I'm hoping we can get into 2.6, but which I probably can't
> afford to put enough effort into on my own:
> * Tweening code (Pierre)
> * Animated Panning (Pierre)
> * Zoom/transition code (Paul)
> * Google Popups (tcolter? Maybe others?)
> * Internationalization framework (madair)
> (Translation is less important to me than having the framework in
> place.)
> One thing I think it would be nice to have, if it's anywhere near
> 'complete' enough, is the SVG text rendering stuff... but I expect
> that's still far enough off that trying for 2.6 is silly.
> So, in summary:
> Things that I will write the code for:
> #1273 (reprojection of layers), #1271 (OSM Format), Maybe #1272 (GPX)
> Things I'd like to see, and will work to review once patches are
> available:
> #110 (animated panning), #933 (transition), #926 (Google Popups),
> #109 (internationalization)
> I'm hoping that the people who are currently working on these four
> chunks of code can step up and say what they're currently stuck on, if
> anything, and what can be helped with to get these changes into trunk.
> The sooner this happens, the more likely it is to make it into 2.6.
> If anyone else has a list like this for their 2.6 wishlist, please
> share -- sharing ahead of time means that we can not spend so much time
> going back and forth in the meeting next week.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
