[OpenLayers-Dev] question about upcoming projection support
Christopher Schmidt
crschmidt at metacarta.com
Tue Jan 15 07:57:54 EST 2008
On Tue, Jan 15, 2008 at 01:14:25PM +0100, Bart van den Eijnden (OSGIS) wrote:
> I asked since if Bounds will be changed accordingly, and toString and
> fromString will be extended with it, I could keep this approach. Otherwise I
> need to add a CRS column to my datamodel and manage this info myself. No
> problem, but just to know which approach I should follow ....
Gotcha. I'd say that the latter is probably the right way to go.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
