[OpenLayers-Dev] Personal 2.6 Goals
Mike Adair madair at dmsolutions.ca
Tue Jan 15 10:21:27 EST 2008
>  * Internationalization framework (madair)
>     (Translation is less important to me than having the framework in
>     place.)
I think I have my sandbox fixed up and merged with trunk properly now so
I'll be preparing a patch for the I18n framework this week.  There is
some translation done, but not much and only with my rudimentary
French.  Support for other languages and translation can easily be added
after the fact.
One other thing I would like to get on the 2.6 list is support for the
MapGuide Layer type.  This is pretty much ready to go, although I do
have one question about overriding initGriddedTiles to set th grid
origin at the upper left (rather than lower right) which I will ask
about in the ticket.  Again I'm aiming to have a patch by the end of
this week.
Missing for both of these is test cases which I likely won't get to this
week, help on writing test code would be gladly accepted.
For the projection stuff,  I'll let others get the support implemented
within OpenLayers and I'll work on getting proj4js tested and
completed.  At this point, the projection class code is working and
tested for lcc, utm, tmerc, merc, stere and sterea (almost) - (this is
the proj= param in the proj4 init string).
Mike
More information about the Dev mailing list
