[OpenLayers-Dev] question about upcoming projection support
Erik Uzureau
erik.uzureau at metacarta.com
Tue Jan 15 12:31:51 EST 2008
hi bart, the toString() function I think was mostly just designed for
debugging... not so much as a way to translate the bounds into a storable
string format.
I think your point is a good one... unfortunately, it wouldn't be proper of
us to change a thing like this now because it would be a breach of API.
for the OpenLayers 3.0 release, however, I think this would be a great thing
to change.
erik
ps. if you really need this functionality, we could put in a patch for a
function with a different name (saveToString() or something like that) for
the time being and mark the current toString() as deprecated...
On 1/15/08, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hmm, one more thing, isn't it strange that toString and fromString use
> different string formats?
> I was hoping to use toString and create a bounds again from the same
> string
> using fromString.
> But toString uses:
> left-bottom=(23560.672130601146,384199.8282873455)
> right-top=(50198.73747014423,401559.87359025853)
> and fromString interprets only something like:
> 23560.672130601146,384199.8282873455,50198.73747014423,401559.87359025853
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Christopher Schmidt <crschmidt at metacarta.com>
> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> Cc: Christopher Schmidt <crschmidt at metacarta.com>, dev at openlayers.org
> Onderwerp: Re: [OpenLayers-Dev] question about upcoming projection support
> Datum: 15/01/08 10:58
> > On Tue, Jan 15, 2008 at 01:14:25PM +0100, Bart van den Eijnden (OSGIS)
> wrote:
> > > I asked since if Bounds will be changed accordingly, and toString
> and
> > > fromString will be extended with it, I could keep this approach.
> Otherwise I
> > > need to add a CRS column to my datamodel and manage this info
> myself.
> No
> > > problem, but just to know which approach I should follow ....
> > Gotcha. I'd say that the latter is probably the right way to go.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080115/7cca4829/attachment.html
More information about the Dev
