[OpenLayers-Dev] question about upcoming projection support
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Jan 15 13:09:51 EST 2008
Hi Erik,
I have worked around it, I don't use toString now but toArray() and do a
join with ",". This format I can read in with fromString.
I've filed a ticket though for 3.0:
http://trac.openlayers.org/ticket/1275
Thanks.
Best regards,
Bart
Erik Uzureau schreef:
> hi bart, the toString() function I think was mostly just designed for
> debugging... not so much as a way to translate the bounds into a
> storable string format.
> I think your point is a good one... unfortunately, it wouldn't be
> proper of us to change a thing like this now because it would be a
> breach of API.
> for the OpenLayers 3.0 release, however, I think this would be a great
> thing to change.
> erik
> ps. if you really need this functionality, we could put in a patch for
> a function with a different name (saveToString() or something like
> that) for the time being and mark the current toString() as deprecated...
> On 1/15/08, *Bart van den Eijnden (OSGIS)* <bartvde at osgis.nl
> <mailto:bartvde at osgis.nl>> wrote:
> Hmm, one more thing, isn't it strange that toString and fromString use
> different string formats?
> I was hoping to use toString and create a bounds again from the
> same string
> using fromString.
> But toString uses:
> left-bottom=(23560.672130601146,384199.8282873455)
> right-top=(50198.73747014423,401559.87359025853 )
> and fromString interprets only something like:
> 23560.672130601146,384199.8282873455,50198.73747014423,401559.87359025853
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Christopher Schmidt <crschmidt at metacarta.com
> <mailto:crschmidt at metacarta.com>>
> Naar: Bart van den Eijnden OSGIS < bartvde at osgis.nl
> Cc: Christopher Schmidt <crschmidt at metacarta.com
> <mailto:crschmidt at metacarta.com>>, dev at openlayers.org
> <mailto:dev at openlayers.org>
> Onderwerp: Re: [OpenLayers-Dev] question about upcoming projection
> support
> Datum: 15/01/08 10:58
> > On Tue, Jan 15, 2008 at 01:14:25PM +0100, Bart van den Eijnden
> (OSGIS)
> wrote:
> > > I asked since if Bounds will be changed accordingly, and
> toString and
> > > fromString will be extended with it, I could keep this
> approach.
> Otherwise I
> > > need to add a CRS column to my datamodel and manage this
> info myself.
> No
> > > problem, but just to know which approach I should follow ....
> > Gotcha. I'd say that the latter is probably the right way to go.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> Dev mailing list
> Dev at openlayers.org <mailto:Dev at openlayers.org>
> http://openlayers.org/mailman/listinfo/dev
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
