[OpenLayers-Dev] Popup Changes
Paul Spencer pspencer at dmsolutions.ca
Fri Jan 18 10:25:46 EST 2008
On 18-Jan-08, at 10:07 AM, Pierre GIRAUD wrote:
>> Second change: http://trac.openlayers.org/changeset/5716
>> Started using images, but no alpha hack yet. While doing that (or
>> maybe
>> a little before), I put the image references in a hash to make them
>> easier to deal with.
> Sorry, I didn't get a close look at the art design and images before,
> but I know wonder why we don't deal with the well-known (hum, think
> so) "sliding doors" effect [1] and manage only one image for the whole
> popup, as GMap already does. [2]
> Extjs also relies on such a technique for the buttons for example, and
> it works well. One main advantage : less images to download at once.
> I'll check that soon, and will tell you how difficult it is to get
> this working.
Pierre,
I think the "sliding doors" technique requires at least two images and
the technique is typically limited to resizing in one direction
(either vertically or horizontally) and has to be fixed in the other
direction based on the design of the images.  Not sure if this is a
requirement here or not.
Our design guy did come up with a way to resize both dimensions using
four images, but I'm not sure if he got the technique to work (it
wasn't in relation to OpenLayers, it was some other thing he was
working on, but it could apply).  This is a bit more complicated to
set up (div container, two more divs inside that have to be set up
correctly to contain the sliding doors images, and two more images to
make the missing corners) than sliding doors.
Cheers,
Paul
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the Dev mailing list
