[OpenLayers-Dev] SelectFeature conflicting with drag-to-zoom
rectangle?
Eric Lemoine
eric.c2c at gmail.com
Tue Jan 22 15:35:19 EST 2008
On Jan 21, 2008 5:05 PM, John R. Frank <john.frank at metacarta.com> wrote:
> > > > In this example,
> > > > http://www.openlayers.org/dev/examples/boxes-vector.html
> > > > one can cause a zoom rectangle to freeze in place and not zoom by
> > > > attempting to release the zoom rectangle over one of the boxes.
> > > I can't reproduce the problem on
> > > <http://www.openlayers.org/dev/examples/boxes-vector.html>. Is it
> > > because Chris has changed the example not to use "hover:true"?
> > Weird. I know I'm using the same browser and platform as John, and I
> > can't get it to happen either. I also tried setting hover: true, just
> > for yucks, and I can't get it to happen in that case either.
> Orientation of drag box matters:
> HOW TO DO IT:
> Click above and to the right of a box.
> Shift-click-drag down and the left.
> Release in box.
> Chris just did it himself too.
> You can reproduce it by dragging very quickly and the cursor disconnects
> from the drag-box.
Ok I'm reproducing the bug and having lots of fun with it :-) Has a
ticket been filled for this thing?
Eric
More information about the Dev
