[OpenLayers-Dev] Zoom to GML-Layer after loading
bartvde at osgis.nl bartvde at osgis.nl
Thu Jul 10 08:01:51 EDT 2008
Probably the extent of the layer defaults to the extent of the map, so
nothing happens. You can easily check this with Firebug.
I see 2 options:
1) you loop over alle the features in the layer and calculate the bounds
yourself
2) you look at my patch for ticket 1613
(http://trac.openlayers.org/ticket/1613) which also parses the boundedBy
element from a GML file (assuming your GML file has a boundedBy for the
whole feature collection).
Btw, please don't cross-post to users and dev if it is not really necessary.
Best regards,
Bart
> Hi folks
> i want to zoom to the extent auf a GML-Layer, after it has been loaded.
> My idea is:
>    1. defining the layer, name it aLayer
>    2. adding a "loadend"-event to the layer
>    3. zooming map to maxextent()
>    4. within the loadend-function I say
>       map.zoomToExtent(aLayer.getExtent());
> Theoretically it sounds good, but in partical work there is a problem:
> map.zoomToExtent(aLayer.getExtent()); does not redraw my map
> any ideas why ?
> Mit freundlichen Grüßen / Yours faithfully
> Carsten Eider
> Dipl. Inf. (FH)
> Kompetenzzentrum für Innovative Informationssysteme
> c/o Fachhochschhule Bingen / University of applied sciences Bingen
> Berlinstraße 109
> 55411 Bingen
> Tel: +49 (0) 6721 / 409-179
> Fax: +49 (0) 6721 / 409-158
> email: eider at fh-bingen.de
> Internet: iis.fh-bingen.de
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
