[OpenLayers-Dev] Format.XML question
Tim Schaub
tschaub at opengeo.org
Thu Jul 10 17:12:30 EDT 2008
Hey-
bartvde at osgis.nl wrote:
> Hi list,
> is there a way to limit getElementsByTagNameNS to a certain level?
> For instance a GML FeatureCollection can have a boundedBy element on the
> highest level, but also theoretically one per feature. I am only interested
> in the first one, and currently I have to check the parentNode to be sure I
> am dealing with the right one. A level in getElementsByTagNameNS would be a
> nicer approach IMHO.
The xml.getElementsByTagNameNS method is just a cross-browser wrapper
for the DOM:element.getElementsByTagNameNS method. Its behavior follows
the W3C XML DOM specification.
It is a hugely inefficient way to traverse the dom (particularly in IE),
and you can typically find a better way.
If you're talking about GML parsing, I've worked up a new parser that I
need to make into a patch.
http://trac.openlayers.org/browser/sandbox/topp/almanac/lib/OpenLayers/Format/GML/Base.js
This parser calls getElementsByTagNameNS once instead many, many times
as with the parser in the trunk.
Tim
> What do people think? Am I missing something?
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,48737694268471804284693!
More information about the Dev
