[OpenLayers-Dev] Mouse Wheel
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Fri Jul 18 05:06:24 EDT 2008
actually Kyle is not pointing at the same problem. The former discussion
asked why OL didn't center the map on the position of the mouseWheel,
which is indeed a bad idea.
As Chris said in his reply, OL zoomwheel keeps the same point under the
cursor, just as GoogleMaps does.
But it looks like Kyle doesn't get this kind of behaviour, which works
perfectly fine in the examples page
(http://www.openlayers.org/dev/examples/example-list.html)
any more hint Kyle (browser version for instance ? )
Thanks
Guillaume
bartvde at osgis.nl a écrit :
> It's by design, see:
> http://www.mail-archive.com/users@openlayers.org/msg03396.html
> Best regards,
> Bart
>> When you use the mouse wheel to zoom in and out, shouldn't the point
>> under the mouse cursor stay the same? This works as expected with
>> Google Maps, but fails miserably with OpenLayers. I'm wondering if
>> this is something that would be easy to fix, assuming the default
>> behavior is to just zoom from the center of the map instead of from
>> the mouse position.
>> Kyle Mulka
>> http://www.kylemulka.com
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev
